Seestar S50 Pro
Price range: $999.00 through $1,098.00
2-year free warranty service
Seestar S50 Pro Smart Telescope
50mm Aperture. The Universe, Revealed.
Pro Performance. Built to Explore.
Five major upgrades. One powerful new Seestar.
50mm aperture 4k view 9 hour battery
Professional-Grade Imaging
All-in-One. Ready for more.
Traditional astrophotography often requires multiple devices—such as a telescope, equatorial mount, and camera—along with complex wiring and setup.
Seestar integrates its core imaging system into one compact device for easy carrying and fast setup. Whether you’re on a family trip or embarking on your next outdoor creative adventure, capture the beauty of the universe whenever inspiration strikes.
seestar-s50-pro-professional-grade-imaging
Just Three Steps
Create Cosmic Shots in Seconds
seestar-s50-pro-Three-Steps-Cosmic-Shots-in-Seconds
From Deep-sky to Everyday Viewing, Capture It All
Four modes cover the universe and the world around you, bringing every discovery into clear view.
seestar-s50-pro-everyday-viewing
seestar-s50-pro-four-modes
50 mm Large Aperture
Sharper Detail. Greater Light-Gathering Power.
With nearly three times the light-gathering area of a 30 mm aperture, the 50 mm aperture delivers faster light collection and greater optical resolving power. Paired with a 4K 1/1.2-inch large-format sensor, it reveals rich detail—from faint structures in deep-sky objects to the intricate textures of the Sun and Moon.
seestar-s50-pro-50mm-large-aperture
Deep-sky sample images
seestar deep sky image details comparison
DSO Mosaic Stitching
Telephoto mosaic capture stitches a wider frame while preserving telephoto detail. It expands the field of view and can output up to 8K high-resolution images.
seestar-s50-pro-DSO-Mosaic-Stitching
Professional-Grade Optical Design
Folded optical path design, compact and portable.
seestar-s50-pro-professional-grade-optical-design
4-Element Apochromatic Lens
The result is a night sky rendered with clarity and balance — true to what the eye expects and the universe deserves.
Triple Filter System
Astronomical light pollution filter reduces interference from moonlight and urban light pollution.
Dark frame filter subtracts noise from long exposures.
IR-cut filter blocks infrared interference for cleaner astrophotography.
seestar-s50-pro-4-Element-Apochromatic-Lens-Triple-Filter-System
4K Dual-Lens
Ultra-Clear Imaging to See Deeper and Capture Wider
Telephoto and wide-angle cameras work together, both supporting 4K UHD resolution.
The telephoto camera features a 1/1.2″ large sensor for clearer deep-sky object details.
The wide-angle camera records a broader starfield, keeping the whole scene in frame.
The dual-camera system balances deep-sky capture with wide-field astro shooting.
seestar-s50-pro-4K-Dual-Lens
Massive Object Database. One-Tap Smart Stargazing.
Select a target in the app and tap GOTO. Seestar automatically locates, tracks, and captures it, delivering cosmic shots in minutes.
seestar-s50-pro-massive-object
One-Tap Post-Processing. Advanced Editing.
Get a polished result with one tap, or take more control with advanced editing tools including star reduction, star removal, cropping, brightness, contrast, noise reduction, saturation, and more. Refine every detail and bring your imagined shot to life.
seestar-s50-pro-one-tap-post-processing
seestar-s50-pro-polished-result-with-one-tap
Pro-Level Milky Way Shots
Captured in One Tap
seestar-s50-pro-milky-way
More Freedom to Frame, a Wider View
Starry Sky Mode supports multiple Milky Way stitching options.
seestar-s50-pro-free-frame-woder-view
One-Tap Milky Way Arch, 8K Masterpieces Instantly
seestar-s50-pro-milky-way-arch
Freeze the Ground, Two Worlds in Perfect Focus
Intelligently detects and locks the foreground landscape, processing it separately from the sky. Landscape freeze duration can be customized. Stars stay sharp during tracking while the landscape remains clear and natural, creating crisp, striking astro landscapes.
seestar-s50-pro-freeze-ground
Recognize constellation lines and labels with one tap, then quickly GOTO the target.
Even beginners can easily find their own constellation.
seestar-s50-pro-intelligent-constellation-recognition
Star Trail Masterpieces, Effortless.
Long-exposure star trail captures can be automatically turned into dynamic videos, showing the night sky moving over time for more impactful results.
seestar-s50-pro-star-trail-masterpiece
Sun. Moon. Action.
Seestar makes it easy to capture sunspots, lunar surface details, and rare celestial events such as solar and lunar eclipses. More than a pocket observatory for the night sky, it also serves as a super-telephoto viewing camera for daytime use. From birdwatching and distant landscapes to rocket launches, Seestar is ready to capture it all.
seestar-s50-pro-sun-moon-details-lunar-surface
Long Battery Life. Big Storage. Keep Inspiration Going.
Upgraded to a 10,000mAh battery, with up to 9 hours of stargazing.
More peace of mind for all-night observation and more fun for camping under the stars.
seestar-s50-pro-9hour-battery-life
Plan Mode
Let Seestar Handle Your Night Sky Workflow. Effortless All-Night Shooting. Set it once and leave it to run all night.
seestar-s50-pro-run-all-night-plan-mode
Generate a shooting plan with one tap
Multi-Target Continuous Shooting
Automatically switches targets by plan to capture more celestial objects efficiently.
seestar-s50-pro-shooting-plan-multi-target
Equatorial Mode
Offsets the effect of Earth’s rotation when tracking celestial targets, enabling stable tracking and longer exposures so objects stay “still” in the frame.
Seestar S50 Pro features a precision drive system with  h. Combined with Equatorial Mode, it delivers faster, smoother tracking and fine adjustments for a significant boost in imaging efficiency.
seestar-s50-pro-equatorial-mode
New Upgraded Tripod. Stability, Leveled Up.
Adjustable Angle
More angle options for more shooting terrain
seestar-s50-pro-tripod
AI Assistant
Your Stargazing Friend.
The AI assistant helps with observation, imaging, celestial knowledge, and operation guidance.
Just say the celestial target you want to see. It quickly searches the target, performs GOTO positioning, and starts capture, making stargazing more natural and efficient.
seestar-s50-pro-AI-assistant
Remote Control
Connect to Your Starry-Sky Device from Anywhere
Keep remote devices under control so weather, location, and time no longer limit your imaging efficiency.
Connect remotely to observe, capture, and organize files with ease. Whether your local sky is cloudy, heavily light-polluted, or in daylight, you can connect to a device in a better observing location and keep creating.
seestar-s50-pro-remote-control-device
Advanced Features. Go Further.
Seestar gives advanced creators more freedom.
Open Expansion
Supports the open ASCOM Alpaca protocol and connects to third-party astronomy software such as N.I.N.A., expanding automated observation and advanced imaging workflows.
From a smart stargazing device to an open astronomy creation platform.
seestar-s50-pro-ASCOM-Alpaca
Join the AstroImg
A community of people who love the stars, exploring the sky, creating images, sharing passion, and exchanging inspiration together.
seestar-s50-pro-astrolmg
What’s in the box
seestar-s50-pro-what's-in-the-box
Model Comparison
seestar-s50-pro-model-comparison
FOV
FOV comparison
Specification
Seestar S50 Pro specifications
FAQ
Q: What can the new wide-angle camera on the S50 Pro do?
A: The S50 Pro features a 4K wide-angle camera with a 63° field of view, enabling:
1. One-Tap Milky Way Arch: Automatically captures and stitches a complete Milky Way arch—no need to manually plan stitching points.
2. Milky Way Time-Lapse: Record the movement of the Milky Way and watch it drift across the night sky.
3. Star Trail Photography: Use long exposures to capture striking circular star trails.
4. 8K Stitching: Create ultra-high-resolution wide-angle panoramas that stay sharp even when enlarged.
5. Wide-Field Live Stacking: Enhance wide-field image quality in real time for cleaner results, faster.
Q: What post-processing upgrades does the S50 Pro offer?
A: The S50 Pro now supports Smart Enhancement and one-tap image processing, including Star Reduction, Star Removal, and Noise Reduction.
Star Reduction makes stars smaller, bringing deep-sky objects such as nebulae and galaxies into clearer focus while preserving a natural star field for a cleaner, more refined image.
Set Star Reduction to 100% to enable Star Removal, which removes stars from the image and highlights the textures, contours, and faint details of deep-sky objects.
Noise Reduction is automatically applied in Smart Enhancement.
Q: What is the S50 Pro’s one-tap plan mode feature?
A: Based on your target and shooting conditions, Seestar can quickly generate a shooting plan and carry it out automatically. Even if you are unsure what to shoot or how to set the parameters, smart recommendations help you get started with less manual setup and fewer repeated steps.
Q: What can S50 Pro’s Telescope Network feature do?
A: Telescope Network lets you remotely control the S50 Pro for imaging. You can also share or transfer device access, and batch-export photos after a session. Capture and access your images even when the device is not by your side—for a more flexible everyday experience.
Q: How is the S50 Pro tripod different from the S50 tripod?
A: The S50 Pro features a new two-section tripod with two adjustable leg angles. It supports a wider adjustment range, adapts flexibly to different terrain, and provides a more stable shooting experience.
Q: How much internal storage does it have?
A: The S50 Pro has 128 GB of internal storage, with approximately 100 GB available for use.
Q: I already own an S30 Pro. Is it worth upgrading to the S50 Pro?
A: The S30 Pro is a portable all-rounder for a wide range of shooting scenarios. The S50 Pro is built for deep-sky imaging, with a larger aperture, a more capable tracking system, and richer image detail.
If portability and versatile everyday shooting are your priorities, the S30 Pro remains an excellent choice. If you want to capture fainter deep-sky objects and pursue greater imaging detail, the S50 Pro is the better upgrade.
Important Notes
Seestar series products are available in two regional versions: Mainland China and Overseas. The Mainland China version is intended for activation and use exclusively within Mainland China, Hong Kong, and Macau. Activation in other regions is not supported, and products activated outside these designated regions are not eligible for warranty or after-sales service.
Handle with care. Seestar smart telescope is a precision optical and electronic instrument. Avoid drops, impacts, or strong shocks, which may cause damage.
Image results may vary. Imaging performance depends on environmental conditions such as light pollution, atmospheric transparency, parameter settings, and stacking duration. Actual results are subject to real‑world shooting conditions.
[1] At 1× magnification, both the telephoto and wide‑angle cameras capture images at 4K (3840 × 2160) resolution. Resolution decreases at 2× and 4× magnification. The real‑time live preview stream for both cameras is 1080P.
[2] Milky Way imaging requires dark‑sky conditions. In areas with significant light pollution, Milky Way details may be limited or not visible. Results depend on on‑site observing conditions.
[3] NFC functionality requires a compatible smartphone. Support varies by device and model—please refer to your phone’s specifications.
To use NFC, ensure the telescope is powered on, the phone is unlocked, and Wi‑Fi, Bluetooth, NFC, and GPS are enabled on your phone.
NFC sensitivity varies by device due to antenna placement. Locating your phone’s NFC sensing area may improve detection.
If the Wi‑Fi name is changed, NFC information must be updated manually for NFC to work properly.
[4] Due to system usage and storage allocation, available capacity may vary. System updates may affect storage allocation. Please refer to the actual available capacity on your device.
[5] Under ambient temperatures above 25°C, with Alt‑Azimuth Mode and Telephoto Sensor Stargazing Mode enabled, the battery provides up to 9 hours of runtime. Data provided by the ZWO laboratory for reference only. Actual performance may vary.
Data provided by ZWO Laboratory for reference only; actual performance may vary.
[6] 60 s long exposures are supported only in Equatorial Mode and are not available in Alt‑Azimuth Mode. Accurate polar alignment is required in Equatorial Mode to ensure precise tracking. Inaccurate alignment may reduce imaging performance.
[7] A solar filter must be installed when observing the Sun. Never allow the main camera to observe the Sun directly, as this may cause permanent damage to the device.
[8] The Smart Enhancement feature optimizes noise in actual astrophotographic images and enhances the stars captured in those images. It works like beautification applied to existing photos and does not generate AI‑created images. This product is an intelligent astronomical telescope, and all images are authentic captures without AI‑generated content.
[9] Wi‑Fi transmission range is measured under ideal conditions. ZWO Laboratory testing shows a range of up to 10 meters in an open outdoor environment without interference. Actual range depends on real‑world conditions.
[10] Sudden changes such as cloud cover, rain, or strong winds may prevent task completion. The device does not automatically power off in these situations. Please confirm weather conditions before scheduling an imaging plan.
[11] Telescope Network Remote Access is available for a limited‑time free trial during the beta period.
Model Structure
seestar-s50-pro-model-structure
Product NameSeestar S50 Pro
Sensor SizeTelephoto: 1/1.2 in   2.9 μm (8.3 MP)
Wide‑Angle: 1/2 in   1.6 μm (8.3 MP)
Sensor ModelTelephoto: OmniVision OS08B10
Wide‑angle: IMX586
ResolutionTelephoto: 2160×3840 (8.3MP)
Wide‑Angle: 2160×3840 (8.3MP)
Field of ViewTelephoto: 2.8° (Portrait)
Wide‑Angle: 63° (Portrait)
ApertureTelephoto: 50 mm
Wide‑Angle: 3.4 mm
Focal RatioTelephoto: f/5.2
Wide‑Angle: f/1.75
Focal LengthTelephoto: 260mm
Wide‑Angle: 6mm
Equivalent Focal LengthTelephoto: 880mm
Wide‑Angle: 35mm
Working DistanceTelephoto: 15 m‑∞;
Wide‑Angle: 0.1 m‑∞
Optical Design4‑Element Apochromatic Lens (APO), Including ED Glass
Built‑in FiltersUV/IR‑Cut Filter (Telephoto + Wide‑Angle)
Dual‑Band Light Pollution Filter: OIII 30 nm / Hα 20 nm (Telephoto Only)
Dark Frame Filter (Telephoto Only)
External FilterMagnetic Solar Filter
Storage Capacity128 GB eMMC
*Due to the storage chip and system usage, approximately 100 GB of storage is actually available.
Battery Capacity10,000 mAh; up to 9h of runtime (ZWO laboratory test data)
Power InputType‑C, Supports DC 5V‑3A; 12V‑3A
ConnectionsWi‑Fi, USB Type‑C, Bluetooth
Wi‑Fi ResetSupported
Image FormatJPEG / FITS
Video FormatMP4 / AVI
Wireless Wi‑Fi5 GHz / 2.4 GHz
Wi‑Fi Range*Up to 10 m
Bluetooth Range*Up to 5 m
Mount TypeAlt‑Azimuth; Equatorial Mode Supported
Slew Rate1×‑1440×
Home PositionMechanical Home Position
Base Port3/8‑16
Operating Temperature‑10℃~40℃
Charging Temperature0℃~40℃
Storage Temperature‑10℃~60℃
Operating Humidity20%~80%
Storage Humidity20%~50%
Weight2.8kg (Main Unit)
Dimensions140×149×268mm (Folded)
Be the first to review “Seestar S50 Pro”
Additional information
Choose to Buy
S50 Pro, S50 Pro+TH10 (with a FREE Quick-Release Plate), S50 Pro+Quick-Release Plate
