$599.00 – $678.00
Note: Seestar series products are available in two regional versions: Mainland China and Overseas. The Mainland China version is intended for activation and use exclusively within Mainland China, Hong Kong, and Macau. Activation in other regions is not supported, and products activated outside these designated regions are not eligible for warranty or after-sales service.
1. Lightweight: Weighs only 1.65 kg.
2. Intelligent: Smart app control with GOTO and automatic tracking — enjoy stargazing anytime, anywhere.
3. Easy to Use: A highly integrated, all-in-one system that combines the telescope, auto focuser, camera, Alt-Az mount, filter Wheel and controller into a single, compact setup. Just power on and start exploring.
A dual-lens system with 4K wide-angle and telephoto cameras, elevating smart telescope imaging to a professional level. Powered by a telephoto IMX585 (1/1.2″, with a light-sensitive area 4× larger than S30) and a wide-angle IMX586 sensor, Seestar S30 Pro delivers higher resolution, lower noise, and cleaner, more natural image quality.
From distant galaxies and glowing nebulae to the Milky Way in motion — from planets overhead to landscapes below — Seestar S30 Pro captures every perspective in 4K Ultra HD.
The Milky Way drifts across the frame. Star trails trace their quiet paths through time. In time-lapse, the night reveals its vastness, its rhythm, its wonder
The Seestar S30 Pro’s built-in Milky Way stitching automatically creates horizontal or vertical mosaics, expanding the field of view far beyond a single frame while preserving ultra-high-resolution detail.
Lock the landscape, let the sky move. Seestar S30 Pro intelligently separates the foreground from the stars, keeping the Milky Way sharp and free of trails while preserving a crisp, natural landscape — all with a single tap.
Seestar S30 Pro instantly identifies and labels constellations in your view, revealing how stars connect into familiar patterns — clearly, naturally, and at a glance.
Looking for your zodiac? With one-tap GOTO, Seestar automatically locks onto your constellation, removing complexity and letting discovery feel effortless—even the first time.
With access to 80,000+ deep-sky objects and 600,000+ stars, simply select a target in the app and the Seestar will automatically locate, track and capture. Get stunning cosmic images in minutes.
With a single tap, Seestar reduces noise while preserving fine celestial detail — delivering clean, natural images with remarkable clarity.
Apply DBE (Dynamic Background Extraction) to balance uneven backgrounds, making your cosmic shots sharper and more detailed.
The device shoots continuously following a planned mosaic grid and automatically stitches the images, creating grand, immersive visuals.
Each capture breaks through the limitations of a single frame, delivering stunning, expansive astrophotography.
Choose your target and schedule in advance. Seestar takes care of the rest—automatically locating, tracking, capturing, and refining the night sky for you.
No need to stay up all night — never miss a spectacular celestial event.
Designed to counter Earth’s rotation, Equatorial Mode keeps celestial targets precisely tracked—so stars remain sharp and deep-sky objects stay steady in frame for longer exposures.
Additional accessories are required.
Seestar S30 Pro isn’t just a palm-sized observatory for the night sky—it’s also a powerful ultra-telephoto camera for daytime use. From birdwatching and distant landscapes to rocket launches, it brings far-away subjects close with ease.
With photo, video, and time-lapse modes, Seestar quickly locks onto your subject and keeps it smoothly tracked—turning long-distance scenes into clear, stable captures.
The result is a night sky rendered with clarity and balance — true to what the eye expects, and the universe deserves.
A built-in three-filter system adapts seamlessly to different observing conditions—so every scene is captured at its best.
-Dark Field Filter
Automatically suppresses long-exposure noise for cleaner deep-sky images.
-UV/IR Cut Filter
Blocks unwanted infrared light, preserving clarity and true color.
-Light Pollution Filter
Optimized for OIII and Hα, it reduces the effects of moonlight and urban glow—revealing emission nebulae with striking contrast and detail.
Built-in anti-dew control gently regulates the lens temperature to prevent condensation during long sessions, even in cold, humid, or rapidly changing conditions.
The optics stay clear and stable—so your imaging run continues uninterrupted, from first exposure to last.
With 128 GB of onboard storage, you can keep capturing without stopping to manage files or clear space.
No interruptions. No lost moments. Just room to explore, capture, and create.
Remote Control Across Regions
The Sky, Within Reach. Anywhere.
The Telescope Network connects Seestar telescopes around the world into a single, unified network. Simply add your device, and remote control is instantly enabled—across regions and time zones.
Browse celestial catalogs, tap to GoTo and capture targets, and monitor live views and progress in real time.
Even when you’re not on site, you’re still seeing that sky—with your own eyes.
Use simple voice commands to enjoy real-time guidance as you explore the night sky.
Seestar supports the ASCOM Alpaca open protocol, enabling compatibility with a wide range of third-party software, including NINA and more.
From automated observing to fully tailored workflows, Seestar is more than a device. It’s an open platform, designed to grow with your ideas and expand what’s possible under the night sky.
A place where stargazers gather to explore the cosmos, create, share, and inspire.
| Choose to Buy | S30 Pro, S30 Pro+TH10, S30 Pro+Seestar Binoculars |
