From Curiosity to Mastery: The Astrophotography Journey of Puig Nicolas
1. How It All Began
For Puig Nicolas, it all started at the age of 10 with a 60/700 refractor and a 114/900 reflector. His first celestial encounters — the Moon, Jupiter, and Saturn’s rings — sparked a lifelong passion.
After a few years’ break, his love for both photography and astronomy led him naturally into astrophotography. Beginning with an apo refractor and a modified DSLR, he soon transitioned to dedicated astronomy cameras — first the ZWO ASI533MC Pro, then the ASI1600MM Pro — marking the start of a new chapter under the stars.
ASI533MM PRO ASKAR FRA300 M31
ASI 1600 NEWTON 200 IC1311
2. The Setup: Under the Stars
Today, Puig works with two main setups:
  • A 200/800 Newtonian on an EQ6-R Pro mount
  • An ASKAR FRA300 paired with a ZWO ASI294MM Pro and an iOptron GEM45 mount
His Newtonian telescope, fast and powerful, captures exquisite details but can be sensitive to the strong winds common at his observing site. It was this very setup that earned him his first Image of the Day (IOTD) — an unforgettable milestone for any astrophotographer.
Working under a Bortle 6 sky presents constant challenges. “Some objects require an enormous amount of time on the Luminance channel,” Puig explains. “That’s why I often turn to SHO narrowband imaging, which minimizes the effects of light pollution.”
He vividly remembers the first image that appeared on his screen — the Heart Nebula (IC 1805) — captured with an Ha filter and the ASI1600. “It was a unique and unforgettable moment.”
ASI 1600 COCOON H ALPHA
ASI 1600 M81
3. Image Processing
Like many astrophotographers, Puig uses PixInsight for preprocessing.
“The selection of the best raw frames using Blink and SubframeSelector is tedious but essential,” he says. “It’s the only way to ensure maximum signal and detail.”
He acknowledges that modern AI-assisted tools have greatly simplified post-processing but cautions moderation: “Overusing them can make images look artificial, which takes away from the beauty of the real sky.” The finishing touches are done in Photoshop, which he describes as “an indispensable tool for color balance and fine-tuning.”
ASI 1600 PELICAN NEBULA HOO
4. Achievements and Collaboration
Since his first attempts, Puig’s equipment — and skills — have evolved tremendously. As a member of the DSC Deep Sky Collective, he collaborates with other astrophotographers to capture regions of the sky impossible to image alone. Their collective work has earned multiple recognitions, including IOTD and even APOD honors.
He also serves as a judge on AstroBin’s IOTD team, helping to evaluate and celebrate outstanding astrophotography worldwide. “It’s a fascinating and rewarding role,” he says.
ASI 533MM PRO FIRST IOTD
ASI533MM PRO ASKAR FRA300 IC 5068
5. The Ever-Evolving Passion
To Puig, astrophotography is a field that never stops growing — fueled by innovation and the creativity of the community. He hopes to build a personal observatory in the future for greater comfort, safety, and imaging efficiency. “And perhaps someday, I’ll have a setup under a truly pristine sky,” he adds.
He also plans to upgrade his Newtonian telescope and adopt a next-generation ZWO camera to push his imaging even further.
6. A Connection That Matters
“ZWO products are essential in an astrophotographer’s life,” Puig says. “Their simple yet effective design, combined with perfectly compatible accessories, makes everything easier.”
ASI533MM PRO IC1311
ASKAR FRA300 ASI 294MM PRO
ASKAR FRA300 ASI 294MM VDB 152
DSC GK PERSEI APOD NASA
DSC IC342
DSC M51 V2 HA CLIFFS
DSC M106
DSC SN1181
DSC SNRG182.4+4.3
ZWO ASI2600MC PRO COLLABORATION MIKE HAMENDE
