Protective Window
$16.00$49.00
Free worldwide shipping over USD 199
2-year free warranty service
UV IR-CUT Protective Window
D21 UV IR-CUT protect window
Technical Parameter
Diameter: 21mm
Type: UV IR-cut window
Thickness: 1.1mm
Flatness: 1/4 λ
Match Model
ASI120MC-S, ASI178MC.
D25 UV IR-CUT protect window
Technical Parameter
Diameter: 25mm
Thickness: 1.1mm
Flatness: 1/4 λ
Match Model
It is used for ASI174MM ASI174MC ASI174MM-COOL ASI174MC-COOL to protect the sensor from dust and humidity.
D60 UV IR-CUT protect window
Technical Parameter
Diameter: 60mm
Thickness: 2mm
Flatness: 1/4 λ
Match Model
It is used for ASI6200MC Pro, ASI2400MC Pro, ASI2600MC Pro/Duo to protect the sensor from dust and humidity.
AR Protective Window
D21 AR protect window
Technical Parameter
Diameter: 21mm
Type: AR window
Thickness: 1.1mm
Flatness: 1/4 λ
Protect the sensor from dust and humidity.
Match Model
ASI120 series, ASI178 series, ASI290 series, ASI224MC series, ASI385 series, ASI185MC series, ASI220 series, ASI462 series, ASI662 series, ASI678 series, ASI664 series, ASI715 series.
D25 AR protect window
Technical Parameter
Diameter: 25mm
Type: AR window
Thickness: 1.1mm
Flatness: 1/4 λ
Match Model
ASI174 series.
D32 AR protect window
Technical Parameter
Diameter: 32mm
Type: AR window
Thickness: 2mm
Flatness: 1/4 λ
Match Model
ASI1600 series, ASI294 series, ASI183 series, ASI990 series, ASI991 series, ASI585 series, ASI533 series, ASI294 series.
D60 AR protect window
Technical Parameter
Diameter: 60mm
Type: AR window
Thickness: 2mm
Flatness: 1/4 λ
Match Model
ASI071 MC Pro, ASI6200MM Pro, ASI2600MM Pro/Duo.
Be the first to review “Protective Window”
Additional information
Choose to Buy
ZWO D21IR-CUT, ZWO D25IR-CUT, ZWO D21AR, ZWO D25AR, D60-2 AR, D32-2 AR, ZWO D60IR-CUT
