Cooled ASI camera setting in ASCOM driver
As we know all ASI cameras enable us small settings to adjust through ASCOM camera driver such as Gain and Offset. In this short article, we will show you a few test images of how cameras setting affects your captured image. For this test, we used ASI1600MM-Cool and ASI071MC-Cool, two very popular ZWO DSO cameras.
ASI ASCOM camera driver interface is very simple. In this case, we tested only predefined settings values for Gain and Offset. We have three options; highest dynamic range (G: 0 O: 10), unit gain (G: 139 O: 21) and lowest read noise (G: 300 O: 50). Which setting is the best for DSO imaging?
asi-cameras-ascom-settings
ASI1600 camera setting test
The first test we made with a 30-cm f4 telescope on G53F Friction Drive Mount was used, ASI1600MM-Cool and L filter. We point telescope on very popular target M1, the Crab Nebula in the constellation of Taurus. We captured three images with the highest dynamic range, unit gain, and lowest read noise settings. All three images were exposed 200-seconds at -20°C and bias, dark and flat not used. As we see lowest read noise settings give us very saturated images (stars and nebula). The reason for this is very low full well (bellow 1K) at this gain and offset values. Unit gain gives us a much better result. We have saturated only brighter/bigger stars. From our point of view, the best result gives us the highest dynamic range. Gain and offset values for this preset give us full well 20K. We got not saturated stars, good background patterns and also very good SNR. If we exposure too long the sky glow will cover the read noise and there is no big difference with low read noise (LRN) and high read noise (HDR) camera settings.
ASI1600-M1_Gain-settings
Short exposures with HDR and LRN camera settings on same objects give us much more interesting results. Both images were exposed 10 x 10-seconds at -20°C and bias, dark and flat not used. On this case we see LRN image have less noise and higher SNR.
ASI1600-M1_HDR_LRN_10x10sec
Another test images were exposed 20 x 5-seconds at -20°C and bias, dark and flat not used. LRN image has less noise and higher SNR.
ASI1600-M1_HDR_LRN_20x5sec
For the final test, we compared 1 x 1-seconds exposure image at -20°C and bias, dark and flat not used. The result is very similar. LRN image has less noise and higher SNR.
ASI1600-M1_HDR_LRN_1x1sec
ASI071 camera setting test
We also made a test with a 135-mm f2.8 lens, ASI071MC-Cool and L filter (2″ IR-UV CUT ). We point telescope on a very popular Virgo Cluster (cluster of galaxies). Also in this test, we captured three images with the highest dynamic range, unit gain, and lowest read noise settings. All three images were exposed at 200-seconds at -20°C and bias, dark and flat not used.  As we see lowest read noise settings give us very saturated stars, especially in R in G channel. At these values we have full well the only 3K. Unit gain has similar issues, but yes with lees saturated stars. Also in this test, we think the best result gives us the highest dynamic range with full well only 46K.
vigro-cluster-asi017-gain-settings
Short conclusion
Our visually conclusions are, highest HDR settings give better result at longer exposures. We have got not saturated stars, good SNR and also very good or same read noise pattern like images with LRN values. But if you preferred shorter exposures due your “lucky imaging technique” or mount track limit we prefer LRN settings.
57 Comments
  • matt
    Posted March 12, 2017 at 8:58 pm
    Comment *
  • Abduallah Ahmad
    Posted March 14, 2017 at 1:29 pm
    I like the flexibility of Asi1600mm-c , It’s really game changer, I started using my own two week ago , usually I do unity gain with narrowband & It yeld good results at shorter exposures , I’m still learning & I will try LRN & HDR as i got clear sky
    • Post Author
      Sam Wen
      Posted March 17, 2017 at 6:06 am
      thanks just try it
  • Aleix Roig
    Posted March 14, 2017 at 1:37 pm
    Thanks for sharing this “official” article. It’s good to read ZWO opinions in this matter.
    Thans again. Best wishes,
    Aleix Roig
    PRADES, Tarragona (Catalunya-Spain)
    • Post Author
      Sam Wen
      we will do more like this in the future
      • Andrew D.
        Posted October 1, 2017 at 7:19 pm
        This is all new to me so please forgive my newbie questions:
        Can you explain the settings to me? In other words what is “gain” vs “offset”?
        If I make “gain” adjustments in software capture program like Sharp Capture… I assume it is using the ASCOM driver to make those adjustments correct? I don’t have to make adjustments to the driver AND the software capture program.
        Thank you
  • Nicolas Doña
    Posted March 14, 2017 at 3:09 pm
    Hi, thanks for sharing this kind of official evidence.
    I am a user of a non-cooled asi178mc and I would like to know the correct values ​​for long exposures (HDR) and shorter exposures with the “LRN” image technique in order to take advantage of my configuration.
    Thank you
    • Post Author
      Sam Wen
      Posted March 17, 2017 at 6:07 am
      just choose it in the ASCOM
  • Thomas
    Posted March 16, 2017 at 12:59 pm
    Thank you for this write up. Could you please clarify if these images are linear or streched in any way?
    Thank you!
  • Brent
    Posted March 29, 2017 at 5:22 pm
    would the same exposure settings apply to the asi 1600 color, for the 10,5 and 1 second exposures ???
    when using the astrolive software for mac, I only see the option to adjust gain, what offset is it using at gain 300 and is it adjustable ?
    thx for posting this….
    • Post Author
      Sam Wen
      Posted April 14, 2017 at 2:12 am
      you don’t need to adjust offset for live stacking
      you need to use high gain for short exposure
  • jim
    Posted March 29, 2017 at 8:08 pm
    Thanks for this information, Sam.
  • Mike Dennis
    Posted May 24, 2017 at 7:42 pm
    Comment *
  • Mel Davis
    Posted June 13, 2017 at 3:05 am
    Hi Sam
    This ‘instruction’ article is highly informative and very valuable for folks like me just setting up my 1600MC. More like this please!!!
  • Roger Snee
    Posted July 1, 2017 at 4:31 am
    Have just moved across to mono camera from DSLR, and purchased from FLO in the UK, the bundle 2 kit with 31mm filters for f4/f5 Newtonians.
    Obviously lots to learn, and I am currently setting up my Dark and Bias libraries.
    This is an excellent article, and really opens my eyes to Gain/exposure choices.
    Many thanks for this guide, and many thanks for changing my reality, with this excellent camera.
    • Sean Wang
      Posted July 4, 2017 at 9:35 am
      Hoping you will have fun in DSO imaging!
  • julio barros
    Posted September 1, 2017 at 5:17 pm
    hola buen dia. ayer me llego la camara zwo1600 monocroma., tengo el cd de instalacion pero me dijeron que es mejor si busco en el fabricante la actualizacion y lo bajo de ahi.. como podria hacer?? o tengo que instalar todos los componentes del cd? o solo algunos. gracias si me pueden ayudar
    • Post Author
      Sam Wen
      Posted September 4, 2017 at 9:17 am
      you can download from our site
      that’s the newest
  • Dave Hudson
    Posted October 14, 2017 at 10:12 pm
    Sam –
    Compliments to ZWO – not only are you creating great products, but you guys “get it” when it comes to software, drivers, and supporting the customer.
    I have used other cameras in the past, and am quickly becoming a ZWO Fan. I just bought the ASI 1600MC cooled and can’t wait to get out and use it.
    Your manual/guide that came with the camera is excellent as are your posts to support it.
    Well done and keep up the great work!
    Dave
    • Post Author
      Sam Wen
      Posted October 19, 2017 at 6:26 am
      thank you so much
      we are keep moving with your guys’ support
  • Juan Carlos
    Posted November 2, 2017 at 10:32 am
    Hola. En primer lugar felicitarte por este gran trabajo. Tengo la cámara 1600 mmc y no consigo que la temperatura funcione con el maxim dl 5 pro. Que tengo que hacer?. Con SGP funciona correctamente.
    • Post Author
      Sam Wen
      Posted November 8, 2017 at 1:45 am
      MDL 5.23 and up fixed this problem
  • John Gladden
    Posted November 6, 2017 at 2:12 pm
    I need a spacer / adapter ring which will allow attachment of the ASI 071 to a Takahashi 106 in the F5 configuration. The Takahashi has a 48mm female thread. The spacer ring needs to have a make 48mm male thread and have an inside female thread to accommodate a 2″ filter. Is such an adapter available from ZWO?
  • Martin Leitner
    Posted January 16, 2018 at 8:37 am
    Hi Sam! I have the ASI294pro and i am looking for the right gain/exposure values…. it would be very helpfull to have a tool (short program) like this: https://youtu.be/97vUB-5HfVE. It would be very nice, to have this for each of your camera.
  • Michael Phillips
    Posted February 6, 2018 at 3:14 pm
    Hi,
    I just bought a 1600MM-Pro and noticed the driver doens’t include offset any more. Does this affect the way I should use the camera? If so, how?
    • Sean Wang
      Posted February 7, 2018 at 3:35 am
      Hi Michael. Yes, we set a static value for offest, much easy for users. Because someone doesn’t understand offest and usually set a wrong value in photography.
      • Michael Phillips
        Posted February 7, 2018 at 9:30 am
        Thanks for the reply. In the test, you tried different combinations of gain and offset. Now the offset is fixed and hidden, would that affect the outcome of the test above or change the outcomes?
        When should I use unity gain?
        • Post Author
          Sam Wen
          Posted February 7, 2018 at 1:27 pm
          A proper offset value won’t cause any problem
          so just forget offset with these Pro cameras
          you can use unity gain in most cases
  • Mirko
    Posted February 11, 2018 at 2:53 am
    Thanks for posting this information. I find it very useful. I’m really impressed with my results with gain setting at zero. I’d like to try the LRN setting for galaxies at some point.
    • Sean Wang
      Posted February 13, 2018 at 3:54 am
      You are welcome!
  • Mostafa
    Posted April 28, 2018 at 1:27 am
    I have just got the ASI 1600 MM Pro
    I noticed that in addition to the three settings (HDR, LRN and UG) there is a slider tho control the gain. I thought these settings would set the gain automatically. Do I also have to adjust the gain slider or do i just chose one of the three presets?
    • Sean Wang
      Posted April 28, 2018 at 6:00 am
      You can adjust the gain slider manually as you wish.
      • Mostafa
        Posted April 28, 2018 at 5:08 pm
        Thanks what I meant was, when I select one of the presets, does this automatically adjust the gain or do I still need to adjust the gain manually in addition to checking one of te pre sets. In other words, I assume that the HDR setting automatically adjusts the gain to 0 to enable a full well capacity, and the unity gain adjusts the gain to unity etc.. am I right ?
        • Sean Wang
          Posted May 2, 2018 at 1:32 am
          When you select a preset and press set, program will auto adjust the gain.
  • Mostafa
    Posted April 28, 2018 at 12:55 pm
    What I mean Sam is if I use the presets, will these adjust the Gain automatically or do I still need to adjust gain manually
    • Sean Wang
      Posted May 2, 2018 at 1:29 am
      Usually, only use the automatical gain will be great for users. Thoes three gain settings is very typical.
  • Glen
    Posted May 1, 2018 at 12:43 am
    Would LRN be the best to use for very faint objects like maybe Thor’s Helment?
    • Sean Wang
      Posted May 2, 2018 at 1:37 am
      Yes, I think so.
  • Roger Snee
    Posted May 5, 2018 at 7:18 pm
    Hi ZWO,
    Firstly, many thanks for the excellent 1600MMC.
    Some folks have been using Gain values of up to 500 for some NB targets, with relatively shorter exposures.
    Your “benchmark” LRN gain setting is at 300, even though one can adjust up to 600 (I think).
    Could you comment please on whether there is any benefit at all in trying the very high gain settings re read noise?
    Thanks for any response.
    • Sean Wang
      Posted May 6, 2018 at 3:56 pm
      Hi Roger, For 1600mmc camera, gain>300 will be digital gain, read noise will be all the same between gain300-600.
  • Alec
    Posted September 17, 2018 at 7:43 pm
    Hi Sam I have had the ASI1600MM for a while and have now acquired an ASI1600MC. Plenty of information about on gain and offset settings for the MM camera but not a lot of mention for the MC model. What are the recommended settings for the colour camera, are they the same?
    Thanks for help
    • Sean Wang
      Posted September 19, 2018 at 7:59 am
      mono and color, same settings.
  • Alec
    Posted September 20, 2018 at 10:21 am
    Thanks Sam, excellent products
    • Sean Wang
      Posted September 21, 2018 at 2:01 am
      You are welcome.
  • Max
    Posted October 23, 2018 at 9:07 am
    Hi,
    I have the non-cooled asi178mc. I am interested in DSOs and using a guided ES102.
    What is the best Gain and Offset and is their an ideal or recommended exposure length?
    I am trying Gain = 10, offset =30 and 120 sec exposure 24 RGB. would I be better with G=0, O=20 HDR that you recommend above?
    Also if I use higher gain I get bad Amp Glow.
    • Sean Wang
      Posted October 24, 2018 at 2:25 am
      Yes, our default HDR setting was tested by our engineer. A little higher offset like 30 is OK.
      Amp glow can be calibrate by dark frames.
  • Atlas
    Posted October 22, 2019 at 2:23 am
    What is the offset for unity gain (111) on the 183 pro color cooled?
    • Katherine Tsai
      Posted November 14, 2019 at 9:37 am
      You may adjust the offset to make sure the lefta part of histogram is displayed at all.
  • Alex
    Posted October 24, 2019 at 7:30 pm
    Please tell me how to go to the driver to display the field “Pre Defined Settings”? I have version 6.0.3.23 there is no such thing.
    • ZWO ASI Camera
      Posted November 5, 2019 at 2:34 am
      Pelase click on the button which is named “edit”
  • Alex
    Posted October 25, 2019 at 9:00 pm
    Please tell me how to get to Pre Defined Settings? I have driver version 6.0.3.23 – there are no such settings.
    • ZWO ASI Camera
  • graham
    Posted March 1, 2020 at 10:57 am
    Where the hell is this program or is it more out of date stuff. tried the link only to get a error this page not found very frustrating
    • Katherine Tsai
      Posted March 3, 2020 at 8:53 am
      I am sorry for the inconvenience, we will update this.
Galaxy season is here
